The front floor pans in my '67 resto project turned out to be a lot worse than I thought. Initially I fiberglassed in patches, but thought better of it and easily took them back out (a little too easy). To do the job right, I bought SMR front pans (toe boards) and have not much good to say about them. The driver side pan was fairly close to the original,(except that the out side edge is crimped the wrong way) but I wound up just cutting out what I needed and patched it in. The passenger side pan is a different story. It is basically a piece of you-know-what! The contours, cuts, and crimps are waaaay off where they should be, much worse than the driver side repro. I expect that there is probably a fair amount of variation between pans from this outfit, but this is ridiculous, and you'd think that they might do a better job.
Anybody care to share experience in front floor pan replacement using these low quality reproductions?
Tedd
Tedd
