Well I landed a set of 1 1/2" gauges (oil pressure, water temp, volt meter) that come in a bezel that can be removed. I'm stuck as to where I should mount them, at first I thought of mounting in the spot where the dash courtesy lights are (low fuel, door ajar, brake..) but once i took it off clearance will still be an issue. I thought of getting the cigarette pod but that only has two gauges and my guages are smaller than the 2 1/2" slots its made for and on top of that running the plumbing for the water temp or tube for the oil pressure would be too much of a hassle from there. Since I have a standard Cougar I though of also maybe getting rid of the clock (doesnt work) and making a bezel to fit them in that 4" space. Will it fit? What do you guys think? Any suggestions?
