1 - 20 of 26 Posts
Need to fund more of my build, thankfully the expensive part is over.
Will sell cheap, just make an offer if you need anything.
Several extra gauges, cluster faces (XR7 and standard) and circuit boards, I think 2 red and one blue.
rebuildable passenger door hinges
parking brake pedal setup
vacuum tank
rear window tracks with regulators and all brackets
trunk lid hinges and tension rods
vinyl top molding, no broken or stripped studs
several quarter extentions
small sway bar
power steering center drag link
shock towers from 70, no cracks or rust
front turn signals
lots of stainless trim
lots of factory Cleveland engine parts, rods, cranks, timing covers, oil pans
driveshafts, 1 for FMX and one for C-6
automatic shifters and parts
Also have a brand new 16" electric fan that was run for all of about 5 seconds
Lots of other misc. stuff, feel free to ask.
I will start listing some stuff on Ebay this weekend if no takers.
Mike337,
The marker bezels are available repro from at least two manufacturers (good and better).
The gas door box you seek can be made from a crest style box (paint background black) and a '69 headlight door emblem. This is what most people are doing that do not have Eliminators. The Eliminator doors that came on those cars are going to be both hard to find and expensive if you did find one.
Discussion Starter · #4 ·
Bob is correct if you are looking for 69 side marker bezels, but I don't think 70's are being repopped yet. I should also note that most all my stuff is from a 70, so certain things wont work on 69.
I will look through my corner marker stuff and see what I have if it is 70 that you are looking for.
I don't have a nose grille that is in very good shape
I do have the alternator brackets, do you need upper or lower, or both?
Bob is also correct about the fuel door. Best bet is a good crested one and swap the crest for an oversized cat like I did for mine. http://www.mercurycougar.net/forums...t-Cougars-new-fuel-door-trim-is-a-perfect-fit Plus if I had a running cat fuel door I wouldn't sell, lol
Discussion Starter · #5 ·
Forgot to mention that I also have front and rear seats with tracks that need to be recovered
Both fenders
Door panels for standard in dark green, front and rear, not perfect, but good shape
tinted rear glass, both doors (bolt in) tinted drivers glue in and clear passenger bolt in.
Right you are Mike, forgot that your stuff was 70.
Looking for a good rust free vaccuum canister for the headlights.
Ben 913-991-8881
Discussion Starter · #9 ·
I don't have any of the canisters, just the storage tank. I sent all of my canisters to Don a while back.
Andy, I think I am down to only 2 blocks. Both have been bored to .040 though, sleeves aren't cheap, but the 2 bolt I have would probably be good with just a honing if you would be willing to run .040. I did for a while and never had a problem with over heating. The 4 bolt I have was bored .040 but the walls are crusty. The other 2 I have are cracked.
Bob,
Thanks for the info on the gas door flap. I am not trying to pass off an XR7 as an Eliminator as at least one member believes. I have a convert, and am just not a big fan of the crest, when a running cat looks so much better. I will try your suggestion of a 69 headlight door cat on the back.
Thanx,
Mike
Bob,
My pleasure Mike.
Who thinks that? To begin with, the fact that you have a convertible should allay any thought of that.
I have a convert, and am just not a big fan of the crest, when a running cat looks so much better. I will try your suggestion of a 69 headlight door cat on the back...
Hmmm, never really thought about that. I'll have to keep it in mind for the "someday" when there is nothing left to do with my ECI odyssey!
Bob,
Thanx,
Mike
I painted the background on my fuel door black, then epoxied a door panel emblem from a 70 standard (running cat in a rectangular frame) in place of the Lincoln-Mercury crest.
mike,
do you know if you got the bumperettes from your parts car ?If so please let me know i`m looking for a pair for the front.
thanks
pat.
Discussion Starter · #14 ·
No bumperettes, sorry Pat
Whoa, I forgot about this thread, and my question.
Can't do much with 040, man. I need all the 8k rpm stability I can gets.
Discussion Starter · #17 ·
Check the for sale section on the Cleveland forun Andy. Someone just recently posted up a block that was already machined for 300 I think. I believe he also had a standard bore block for 50.
mike337 if you have a 69 , the markerlamp trim is still avaiable from ford, not cheap, but they are available
mike (70fastcat) what would you need to get for the c6 drivershaft? does it still have a trans yoke on it? justin
Discussion Starter · #20 · (Edited)
I will sell all gauges seperately. I have a full set of standards with a working clock and partial set of XR-7. Make me an offer, you wont insult me.
Justin, it does still have the yoke on it, is balanced, and the proper length for your cat. Make me an offer, the tricky part will be the shipping.
Still haven't listed anything yet either, been too busy. May work on that a little over the next week while trying to prepare my taxes.
1 - 20 of 26 Posts
