I wanted to go 285's but I was concerned about fender clearance after I put the 4 piston wilwoods all the way around.Umm, yup! I'm running 285/40/17's and they are the cat's meow.
Do you have discs in the rear? My backspacing is 5" in the rear.No rubbing on 9" wide rims w/5.25" backspacing.
Not yet, but will soon. Putting disks in the rear will have very little effect on the backspacing, at most I would say the disk could be 1/8" thicker are the bolt flange than a drum, if that.Do you have discs in the rear? My backspacing is 5" in the rear.
