1 - 1 of 1 Posts
1970 Mustang Coupe Parts car no title. Everything needed to make a 6cyl to 8 cyl conversion. This car has a rebuildable 302 2 bbl carb engine with C-4 & A/C. About every nut and bolt is still on the engine so you don't have to hunt high and low trying to find pieces to finish an engine rebuild. I can send pics of the car and engine bay. The engine is complete from Fan to Flexplate and includes the C-4 trans and cross member, engine mounts, driveshaft and the Rearend. Rough Body no dr glass and not much inside other than Steering column which is black. Sell whole or eng, trans, rear, A/C. all for $750.00. REDUCED! Now only $650.00 [email protected] or 704-516-8033.
New Cowl Hood for 87-91 Dodge Dakota. 3 inch Cowl Bolt on Hood, Light chips, sells for over $700. Buy this one for only $250.00 or best offer. Can send pictures. [email protected] or 704-516-8033.
1967-68 Mustang Coupe New Pin On Fiberglass Trunk Lid. Light chips to corners. Excellent buy for only $100. [email protected] or 704-516-8033.
1965 or 66 Chevelle or Nova. New Fiberglass Passenger Side Door. I will have to check it out to see which Model it is. Please call or email me. Great buy for only $100. [email protected] or 704-516-8033.
New Full Size Chevy Silverado Ext Cab Westin Chrome Step Bars. Cost over $450. sell for $250. [email protected] or 704-516-8033.
2000 Dodge Ram Full Size Putco Stainless Steel Bed Caps. Great Buy for only $150. REDUCED! Now only $130.00 [email protected] 704-516-8033.
1971 Ford Torino 4 dr body no title $550.00 for whole car or sell parts. Have good Hood $150. Left and right fenders are very good $100 each. Power Steering Drag Link with Slave Cylinder $75. Steering box $50.00. [email protected] or 704-516-8033.
Chevy 327 small journal rods with factory small dome pistons good condition $100. You can bore a 307 oversize to a 4 inch bore & have a std bore 327 inch engine and simply regrind the crank rod journals to small journal size to use these rods and pistons. The crank is the correct stroke.
Newly Reconditioned/Resized small block 400 rods, $100 no cores needed. [email protected] 704-516-8033.
305 Chevy eng assembly ready to build all machine work completed. Selling blk,crank, rods, pistons, heads, New rings, Main & Rod Bearings, New 350 Hyd Cam & Lifters, Oil Pump, Timing set & Gaskets, & 350 4 bbl Cast Intake. All Parts Cleaned, New or Reconditioned $1,000. for all including Block, Crank, Heads and all Parts listed. [email protected] 704-516-8033.
83 Mustang GT Body only w/title. Painted like a 66 Shelby GT 350, Wimbledon White, Blue Stripes. 4" Cowl Hood Pin On Hood from Cervini's. I have already installed a later Model 8.8 Rear. Sell for paint job cost $2,500. No Interior. I removed the interior to repair the floor pan cracks that are common to early Fox bodies & to install a Roll Bar but got involved with other projects & did not finish. I can email pictures. [email protected] or 704-516-8033
1 - 1 of 1 Posts
