Hi, I am having a different problem with my fuels sending unit, I have verified that the wiring, gauge and the unit seem to operating properly, I think the issue is either the float is bad (I bought new and replaced it with the sock) or the float came off the sending unit, which I think is more likely the case. I was considering coming up with another way to fastening the float to the sender arm, but I am not sure what I can use that won't corroded or cause problems with the gas in the tank. Have any of you run across the issue and if so, how did you resolve it? Thank you.
