Have a 70 and have removed the cowl cover and want to take of the bottom trim. There is the clips mounted with screws.
If I remove them comes the trim off automatically or is there something ells that holds it? Want to know before I do something stupid.
Have done a search and have not found the right answer….<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o:p></o:p>
There is an additional screw on each side in the door jambs. Open the doors and you'll see a little tab coming off the molding with a phillips head screw holding it down.
Many thanks for a quick response.… Now it is off the cat…
But found a rubber hmm not sure if that is rubber feels more like a foam under the trim.
Not round it is square in the shape.
Has it no other function than to keep the strip away from the window?
And can I find a new??
Or can I use something that have the same dimension)?
