I have tried to kill an 8 inch and have not succeeded. In 40 years and dozens of Mustangs and other 8 inch equipped fords I never toasted one. The last one I punished was in a 65 Shelby clone that I autocrossed and I flogged it pretty hard with a posi and sticky tires and it never gave up. BUT for those few cars where I built a rather stout motor with serious intentions, I went 9 inch. My current build I sought out a 9 inch.Hi I'm putting together a 68 cougar going to be installing a mild 302 that's around 300-350hp I was wondering how long the stock rearend will hold up thinking around a 3.55 gear too.
I have the same set-up. Warmed over 302 with 8" and 3.55 gearing. No issues what so ever. You might want to go with an AOD if you don't have a standard. A lot of my hot-rod building buddies use the 8" as well. I know of a '39 chevy with blown 350 using 8" for 20 years now without an issue. They're pretty tough.Hi I'm putting together a 68 cougar going to be installing a mild 302 that's around 300-350hp I was wondering how long the stock rearend will hold up thinking around a 3.55 gear too.
