Ever since I've had this car, it has had a flat spot during it's acceleration in 1st gear. I recently replaced the points with a Pertronix III, replaced the plugs, wires, set the timing at 10* BTDC, rebuilt the Autolite 2100 carb, installed a new throttle cable and I've plugged off the leaking headlamp vacuum system, so the system yields 18-20 in Hg. If I do not feather the gas during acceleration in 1st gear, the engine will start to die.
Any ideas?
Cory
Any ideas?
Cory
