1 - 2 of 2 Posts
Hi everyone,
Haven't been back for a while. Finally getting back on track on my 69 Cougar. My question is: can the flaming river column be cut at the base? The distance from the steering box to the base of the column doesn't give enough room for the joint. Also, I can't pull the column back anymore since I won't be able to reach the pedals.
Thanks guys.
Your best bet would be to get in touch with Flaming River, as cutting the column would require cutting the shaft also and having to deal with the splines on the end, unless the shaft is a DD shaft.
1 - 2 of 2 Posts
