1 - 2 of 2 Posts
I've got a VERY interested person for buying my P71. That's means mt Cat, affectionately named "Wanda", is going to live again!!!
However, as a backup plan, what pieces parts from a 1970 351C 4V fit a 1970 302? I did a quick web search and found out that the 2v heads (I have a set) would fit the 302. How about the intake manifold? Anything else?
Thanks, Paul
Cleveland heads on a Windsor block is not a straightforward bolt-on.
The Cleveland (351C) heads will bolt on to a Windsor (302) block, but the water passages must be changed (block passages to the intake, enlarge passages between block and head). On a 302, a Boss 302 (which used Cleveland-style heads) manifold can be used. There used to be aftermarket manifolds made for this conversion. I don't know if any are made currently.
Not much else will fit.
1 - 2 of 2 Posts
