41 - 56 of 56 Posts
Re: The Finagler A/FC Jeff Foulk
Ok, that car is rockin' for a 3.8L. Care to tell how much boost you're running? :)
Times updated. Kept your old ones for historical reasons...
Running 12-13 psi, non-intercooled - I am currently working on a water to air intercooled manifold which will allow me to run 21 psi. That should take me to ~500 rwhp and run the low 11's; we will see. Afer all of that, I have a SVO 4.5 V6 which I will install with a bigger SC and run closer to 30 psi and make ~800 rwhp. That project will be alot of work.
Mike
Discussion Starter · #42 ·
Pics of engine and car at track would be fun to look at when you get the chance!
Made it to a 1/8 mile track last night, but car was not running right, so it only went 9.3 @ 70 mph. I guess thats ok for an engine that wouldn't run over 5,000 rpm in 2nd gear. I will try next weekend for a clean pass, and get the time slip posted. No need to make this one official.
Ok, here it is. If you have a Cougar and have been down the track post to the forum and I will add you in. 1/4 time takes precedence over 1/8 mi time in list.
1. You must be an active member of MercuryCougar.net with a minimum of 50 posts.
2. Car must have run the time within the last few years (my discretion)
Is 1983 recent enough? My best 1/4 mile time ever was 15.21 in a 0F91H. It had a Holley Street Dominator intake and Holley carb. Also a Competition (brand) cam, 3:00 rear end, FMX. I got a lot of high 15's and low 16's. But 15.21 was my best ever. I think I still have a stack of timeslips from 1980-1984
Went to the local 1/8 track today, and faired a little bit better than last time out. I will use this as a baseline before the fine tuning begins. Need to figure out the A/F ratio, its still not running well above 6,000 rpm.
68 Cougar 331 C4, 3.80 gear. No idea of curb weight, full interior and AC.
2.135, 8.948 @ 79.48
I've finely got to go to heartland park in Topeka KS. I drove 91 miles there ran a 11.86 117 mph and drove home. I've put about 5000 miles on it in three years My goal is to run a 11.49 then you need a roll cage, and that aint happening.
Discussion Starter · #48 ·
Heh heh...or find an outlaw track. I was able to run mine at several tracks w/o the bar but kicked off the big tracks with big liability. The mom-and-pop 1/8 mi tracks turned their heads. I won't take mine out without better brakes and a cage now -- too fast for my old ass
Isabel at 4150 lbs is (now) in the 12's with her new 408 Cleveland!
DragBoss Cougar 3200 lbs. Now running 9.69 at 135.77 with a 1.27 60 ft. 6.11 in the 1/8 at 111 mph. This was a launch before I got the front end under control with new DA front shocks by Mark Menscer..,,
Tim,
Just wondering, how do you walk? Your balls are obviously as big as church bells... :buck:
It's been a while. Tim, you have that Cleveland flying. A little update, our Cougar has been a 9.52 @ 139 with a 1.27 60'. That's at 3285 lbs with a 427 windsor and c4 on the footbrake.
I made it to an event at one the local 1/8 mile tracks, and ended up winning the street car class. My fastest pass was 8.713 @ 81.58, with a 2.058 60 foot time. Launching at a lower rpm was the key to my better 60 times, no wheel hop that way.
41 - 56 of 56 Posts
