1 - 20 of 56 Posts
Ok, here it is. If you have a Cougar and have been down the track post to the forum and I will add you in. 1/4 time takes precedence over 1/8 mi time in list.
1. You must be an active member of MercuryCougar.net with a minimum of 50 posts.
2. Car must have run the time within the last few years (my discretion)
Rank Member YR Eng P/A Wt 60' 1/8ET 1/8MPH 1/4ET 1/4MPH
1 Econodrag 67 454 N2O 2950 1.21 5.69 118.5 9.08 141.5
2 Ray-g151 69 X X 3260 1.31 6.25 108 9.88 134.0
3 MJewell 67 408 N2O 3300 1.42 6.32 110.0 9.96 136.x
4 DragBoss 69 385 NA 3285 1.49 6.32 107.76 9.99 133.21
5 xr7 68 428 NA 3560 1.47 x x 10.43 131.2x
6 shan 68 411W NA 3420 1.44 6.70 103.2 x x
11 dfwcatsclub 70 418 NA 3660 1.54 7.13 96.5 11.24 120.5
12 mercinary 69 357 NA X X X X 11.3? 118.X
13 SuperXR7 89XR7 3.8L SC 4016 1.765 7.651 90.64 12.020 112.19
20 SuperXR7 89XR7 3.8L SC 4016 1.865 8.07 88.48 12.495 112 (old time)
30 SuperCJcat 428SCJ NA 1.82 8.36 81.31 13.21 102.22
31 Hawk1 70 351 NA 3890 X X X 13.89 104
41 69HCode 69 351 NA 3650 X X X 14.05 100.00
42 AlphaCat, 73 XR-7 351C-4V NA 3850 x x 14.42 95.14
43 BetaCat 73 XR-7 351C-4V NA 3800 x x 14.41 94.46
44 68Calypso 68 308 NA xxxx 2.42 9.43 76.xx x x
45 MagCats 67 Std 390-4V NA x x x 15.1 x
46 1Bad67Cat 67 357 NA X X 9.78 71.49 X X
50 markseven 67 XR7 289 NA 3060 2.35 10.41 67.88 16.21 83.96
Nice start! I hope to add my 68 when Firebird opens up again this spring...
Alpha- and BetaCat's dragstrip runs were made loooong before modern timing (runs made 25+ yrs ago), so all I can offer is:
AlphaCat, '73 XR-7 351C-4V 3850 lbs, 14.42 @ 95.14 Torker intake, OC heads, stock dish pistons, Crane Fireball cam, headers, 3.70 gears
BetaCat '73 XR-7 351C-4V 3800 lbs, 14.41 @ 94.46 Cast iron intake, cast iron exhaust manifolds, quench 4V heads, Crane Econopower 260 cam, stock duals, 3.70 gears.
Someday :rolleyes: I'll get them back together and on the track... :icon16:
Time to Edit DFWCATSCLUB
Hey DFW time to edit numbers, for myself and Ray. I went best of 6.32 @ 107.76 in 1/8 with a 9.99 @ 133.21 in 1/4. 60ft was 1.49 on back tires. Hopefully this year, can get a little deeper in the nines....Thanks..Tim
mine was on the worn out 351. Now got 47 more cubes and alot more compression. Gotta get it broke in so I can hit the track. Have alot more traction problems now. Will break loose in second without punching it all the way.
Trying to figure out how to edit an old post. Sent Logan an email but no reply yet. Kind of frustrating to have a sticky you can't edit. :)
89 Cougar XR7 232 ci or 3.8 V6 with Whipple 2.3 blower
4016 lbs with me in it, 3.90:1 8.8" with Auburn Pro diff
1.865 60'
8.07'' @ 88.48 mph - 1/8 mile
12.495 @112 mph - 1/4 mile
and there more in her.
Mike
Administrator
...12.495 @112 mph - 1/4 mile
Mike
Gosh, that's enough to make us V8 old-schooler's cry in our Geritol...
Talking about the one in Spokane, WA around airway heights? Maybe I'll see you there! Might even do a run, not with my cougar unfortunately. If you're planning on going send me a PM. It'd be cool to meet up and see your car.
Finagler
2 MJewell 67 408 N2O 3300 1.42 6.32 110.0 9.96 136.x
3 Ray-g151 69 X X 3260 1.31 x x 10.00 132.50
4 DragBoss 69 385 NA 3285 1.34 x x 10.01 134.76
21 whoami
31 Hawk1 70 351 NA X X X X 13.99 101
42 68Calypso 68 308 NA xxxx 2.42 9.43 76.xx x x
43 1Bad67Cat 67 357 NA X X 9.78 71.49 X X
44.Finagler The Finagler '67 A/FC 5.60 8.35 156.96
The Finagler A/FC Jeff Foulk
'67 Cougar A/FC 1/4 mile best 8.35 at Glen Falls NY,May 1970.
1/4 mile best mph 156.96 Suffolk ,Va. Sept.1971
Best 1/8 mile 5.60 New Bethlehem,Pa. May 1974
Discussion Starter #16
Ok, editing available now. Please update or correct
Note: Finagler gets the "*" position based on his post but I'd like to see more info so Finagler: please post up for everyone on what the car is all about.
The rest of the list are considered RUNNING, CURRENT, EVERYDAY racers... :)
I have Time Slip from cica Late 70's from a 1967 Cougar Standard 6.5L 390 4V with C6 Auto and the Rear was Updated to 3.55 Open. Ran a 15.1 in 1/4 at PIR. On Very Early Radials?
Somebody has to take up the bottom of the list, so I challenge anyone to post a slower time than this, and yes, this is my best time.....
Engine: - 289 auto, 3.25 t-loc
Weight: - 3060
60' - 2.35
1/8 - [email protected]
1/4 - [email protected]
The gauntlet has been thrown down............:rolleyes:
New Time
New best time is 13.89 at 104. 3890 lbs with driver. 3.91 gears.
Thanks,
1.865 60'
Mike
How do I put my times on the list?
Mike
1 - 20 of 56 Posts
