1 - 13 of 13 Posts
I am needing to replace the floorpan in my Q code ragtop.
I have two choices.
1. remove a rust free pan from a donor coupe (I have the car in my shop)
2. Purchace the repro one piece pan and patch in the repro 69/70 front panels to make it correct.
The donor car is really nice and if the repro parts are prefectly correct I will go that route and save the car.
Has anyone had experience with the repro stuff? How is it?
I replaced the floorpan in my 68 and nice thing about metal is you can usually form it and make it fit. I bought a repro and it fit just fine. I would save the other car especially if you say it's in good condition. I've never had a problem with the repro floorpans and they are easy to install.
When presented with the option, I would always use original parts rather than reproduction. Since you already have the floor and it's in a car you're parting out, use it.
If you had a 67-8 I would say go repro but since no complete 69-70 correct unit is reproduced I say go with the original. Patchwork quilts will pass when you have no other option but it will always be that, pieced together...
...and if the repro parts are prefectly correct...
For 69/70 they are not, which gives rise to option #2. Seems a little nutty to put in a new full pan and then cut out the incorrect sections to put correct partials, no?
I would say only go with a full repro pan if you could live with the 67/68 pan differences from 69/70..
Otherwise, is #3 an option or is the pan too far gone? Option #3 being putting correct patches in the original pan.
Having been down this very road, let me say that I love, love, LOVE my 69 OEM HT pan transplanted into my 'vert, but I took it from a car that was way far gone in the body and roof areas. Having said that, it is A LOT of work (but the result: Priceless).
That's good to know, I was wondering about that myself.
just roll some duct tape over the holes and put new carpet down. and dont look under the car. :)
I hate to take the floor out of the hardtop, but the convertible is one of 13. Looks like I'm getting out the spot weld cutter!
It always pains me to hear about solid cars being parted and cut up but I guess it has to be done sometimes.
If you're gonna do it, do the job right. Put down some cardboard sprayed with undercoating first. Pop-rivet an old license plate over the bigger holes, if you want to get fancy.
I prefer Barney's Red Green approach...
I did something similar with an old off the back lot beater rambler wagon. Cleaned up floor some, cut some 3/4 plywood to fit, sprayed underside with undercoating and drove it for a year. Car got sold for what I paid for it, only cuz engine was good and it passed emissions. New owner pulled engine and trans and scrapped the rest.
theres a guy on youtube who posted a video on replacing floor pans w/o welding. he used the side panel off an old washer or dryer or something and rivited it in place hahaha.
1 - 13 of 13 Posts
