The best way I know of is to remove them from the corner piece.(fender extension). to remove the fenderextension you have to remove the bumper and lower gravel pan. Then get up inside each wheelwell and remove the fender extension nuts. (3 of them). Remember on the drivers side to remove the vaccumn hose and tank from the forward part inside the wheel well as well. You have to take this out first to get to the 3 nuts for the fender extension. Also remove the rubber bumper fillers from each fender and fender extension. Now with the extension off and in your hands, the 3 nuts on the inside of the fender extension will remove the polished eyebrow trim piece. Clean it, polish it, restore it, or replace it. Does make the Cat look much better. Have fun..
