hi alle,
i'm almost ready to install the exhaust,now i've noticed that there is a part of the chassis in the way to install the exhaust reducer
The solution would be if i had and exhaust recuder with an angle in it
somewhere between 30 to 45°
the reducer i have now is this one
http://www.mustangsunlimited.com/itemdy00.asp?T1=HCR1+01
anyone know where i can find one ?
i looked on summit but they only sell straight ones
Thanks !
Chuck, You will just have to make your own....I ran into the same problem before. Just cut it off and have it welded up - any exhaust shop should be able to handle that.
Take a look at my ECI thread for some ideas. Print the picture off if it helps and show the shop you ask to weld it up for you. On convertibles with long tube headers, the problem is particularly bad as you can see in my picture.
