1 - 15 of 15 Posts
I'm in the process of finishing up the brackets for my twin Superchargers, I figured I could grab hold of another engine to test my system. A buddy of mine is selling an engine that looks like a 390, but I would like to know for sure. How can I read and tell from the V.I.N? where is the engine V.I.N?
On a car? 5th letter in the VIN is the engine designation, don't know about trucks.
ok, well the engine is already out of the car or truck, he's selling the engine and trans for a good price but I want to know if there a stamp on the block or something. But I can always ask him what kind of car or truck he got it from and go from there. I really dont want a 460 if I can avoid it...those things are not really ideal for my test because the heads suck (70's emission crap)
The FE 390 (and all FE's) have a intake manifold that goes under the valve cover about 1/3rd of the way. 5 bolt valve covers 3 on top 2 on bottom. If you can post a pic that would help. Look at www.mustangtek.com and compare some of the parts you saw on it. See if you can tell. Also be sure it's a 390 could be just about anything but the 360's were very common in trucks too. Is this just a mockup engine or something you want to actually use?
I'm planning on using it if it doesn't have any cracks and the cylinder walls look good. I'm replacing all internals if it proves to be a good candidate. I was going to use a 302, but I think twin superchargers is too much compression for such a small engine...
.. To actually tell if its a 390 you need to take the trans and flywheel off, the crank will only have a key way slot, the others will have the slot plus a half moon cutout..
Not a 390.
That be a 429/460. Look for some casting numbers. The heads casting number is easy to find just below the valve cover. If they start with C8VE or D0VE you have a decent starting point. As I recall the D0VE heads were better.
What Bill & Neal said.
Discussion Starter #13
According to www.mustangtek.com the 429/460 had 320-365hp 10.5:1 from 68-71, after that, the smog wars happened and killed the heads to a measly 8.5:1 compression. I wonder if the compression is the culprit for 212hp 72-77 blocks. Would the lower compression be a better candidate for supercharging?
That is also the period of time when the horse power ratings were changed.
Gross to net.
Discussion Starter #15
oh so does that mean they were hiding as far as overall accuracy? What's your 429/460 horsepower estimate?
1 - 15 of 15 Posts
