What is the correct part number that is on the under side of a eliminator hood scoop ?
I think I might have one, that came with a bunch of 70 cougar parts I bought.
Thank You
Thank You
It should only have C9 part numbers on it, iirc there are 4 different ones on the scoop. The front should have 2 stud holes not 3. If it has 3 or a D1 or later it is not original for an Eliminator.
Here are the numbers and words I see FORD ASSY. 40-2742 D14B-16C664AA 40-2444 C9GB-16C664-C 40-2446
FORD PANEL C9GB-C 40-2445
It has its orig paint Blue, All the mounting studs are there.
I am looking to sell it.
Thank You
That is a 71 Comet scoop. Functionaly the same. Just need to use the stud bosses on the front that fit the Cougar hood.
