ID That Eliminator
Beg Pardon, Royce, you are correct.
KMJones, along with the VIN# you will also need the door trim tag ID#'s. The door trim tag is actually a sticker that should be located inside the door jam by the latch, on the drivers side of the car. If you can still read the tag you can then go to the link at the top of this page, then go to the National Clubs link, then go to Classic Cougars of America. Thier home page does have a link to decode your cat. Just plug your numbers into the places where they go. You can also submitt the info to the national registry. If you DO have an Eliminator you should contact Frank Bowers and give him your info so he can also register the car in the Eliminator registry.
If the CCOA decoder tells you that you do indeed have an Eliminator, as Royce said before, you should contact Kevin Marti or Lois Eminger to Verify the VIN#. Unfortunatly the door trim tags are easy duplicate, and some people have begun to fraudulently alter them, for the purpose of makeing the cars more valuable, some models and features (OR feature deletes) ARE more valuable than others.
Please keep new threads posted, and let us know of your progress. You can certainly get any info you may need in the future here, usually from three or four different sources.
Hope this helps, good luck to you.
Shane
:ylsup: :ylsup: :ylsup: :ylsup:
