My friend is having 2 problems, and I'm no help, know nothing about electrics, can't understand wiring diagrams, he's not a member yet, he just bought a 68 xr7, and is starting to restore it.
He says he checked all of the wiring in the car with a test light, pulled the harness, tested each wire, and had a light showing power went thru to the other end. Now has installed it all back, has taillight, headlight, dash lights, but no courtsey lights, either by opening the door, or by turning on by light switch, no wipers, (told him it might the switch), no front marker lights, and no power to overhead console.
Second problem is the alternator diagram shows a 4 wire connection, and his only has a 3 wire, and the stator is hot all of the time.
I know this a lot, thank you in advance
