Can anyone tell me why my LOW FUEL light stays on at ALL times even with the engine off and the key out of the ign. ???
Cause its broken!! ..... Or maybe your low on fuel!
:D No, really, the only thing I can think off is a short of some sort. I don't know much about this stuff (So I probably shouldn't even be posting lol), but maybe something that is on all the time is grounding off into it. I had the same problem with an electric fuel pump. It was grounding off into the right side turn signal indicator!
I had a similar problem whit my wife’s Red-69 XR7.
I had just replaced some cables from battery and mounted a “ Head switch ” for the ground cable. Then when a put everything back a accidentally placed one cable at the wrong side of the starter solenoid so the LOW FUEL kept on lightning what ever I do. Then a found out that the connecting should be at the side facing the firewall ( starter terminal ) instead of the side facing the battery. I think When you engage the starter the LOW FUEL shall light for testing the lamp
Hope you fix it
SwedeCougar
:cyclops:
