Hey guys, I installed a electric fuel pump from Summit that is pushing out really high PSI. My solution was to I put a Holley fuel pressure regulator after the pump to control the pressure and it does nothing, I mean nada, still blows thru that regulator like a busted hose.
1) Is the pump to powerful for that regulator (120 GPH)?
2) I'm running a return line to the tank (since the holley regulator had two outlets) is this necessary?
3) Is the pressure regulator to close to the pump?
