Ok there are 2 EFI harnesses I am looking at for the swap. First one says it is for a Mustang/Cougar/Bronco swap as it has the 4 pin connector to connect the EFI harness at the firewall into the existing Ford harness which I am gathering is for gauges and ignition. The other harness is a universal 5.0 swap harness basically used in other fords, hotrods or Cobra Kits.
Well in my Cougar restomod project I have a painless style universal wiring harness and all the gauges are Auto Meter so there is no original wiring in the car. Do you think I really need to pay $560, almost $100 more for the specific Mustang swap harness or just go for the cheaper Universal one for the $475???
Here are the link to each:
Mustang Swap: http://www.ronfrancis.com/prodinfo.asp?number=TDZ-75
Universal Swap: http://www.ronfrancis.com/prodinfo.asp?number=COBRA-75
go the 2nd, if you have the universal body harness, i think you would happier that one.
Hey I knew you'd answer! Maybe I should of just PM'd you. Well I think you are right but just couldn't bight the bullet until I got someone else's opinion. Man the days of trying to figure out how to install a factory Mustang harness and what wire goes where and what one do I get rid of is over!
haha, i have my head so wraped up in this swap it is not even funny. after further checking out the 2nd harness. i still think it is agood viable option . i really really like the ford harness too its pricey at 575 , but is great and is only 10 wire to connect!
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=9631. i think it is terminated better and has a better fuse/relay setup
Having the ability to datalog and flash the pcm sure is nice. Sometihing to think about the EECV over the ECCIV. To tune the EECIV you need a chip and to figure fuel trims you will need secondary equiptment. Most tuning software has the ability to data log EECV.
