I have a 68 302 with a holley 600 on it right now and runs fine but leaks I have a edelbrock 1406 that I had installed but the engine wouldnt start ! Wanting to go back with that carb! So my question is does it need a thicker carb gasket or maybe A fuel regulator? Oh and its on a performer edelbrock intake
So, the Holley leaks, you tried the Eddy, and want to go back to the Holley, is that right? Or, the engine wouldn't start with the Eddy, but that is the one you want to use?
yes i want to go back with the eddy it has a dual plane eddy intake not sure if i need an adapter?
An adapter is not a no start issue. No fuel, no spark, or no moving parts will cause a no start....
