heh, are they not staying up or are they just hanging low. it could be a leak in your vaccum pump or tubing. what i did when i had that problem was i took out all the vaccum tubing connected to the pumps and replaced them, now they stay up.... too bad they don't come down :cry: :rolleyes: heh well thats another prob i think they're not aligned properly, but i'll fiddle with that later. so yea i think your best bet would be to replace the tubing
1968 Mercury Cougar XR7
Actually, my doors open and close fine, but when they're down they sag and they're a tad crooked. I've tried adjusting them, but all the little rubber bumpers are smooshed, maybe that's the problem.
sad headlight doors
there is a past - past - thread that covers this situation....and also includes a attached photo on how it is done.....someones' own invention that i thought was very ingenuis....drilled a hole just below the door at desired level....and inserted a metal screw or bolt and there you go....instant level doors......check the past threads.....
You could do that... or do what I did... swap the closed stops with the open stops. They are usally not as worn out. it's a PITA but do-able or just do the screw thingy
Don
