Before I take the cat to a body shop or some other place to deal with this problem I thought I would throw it out to the local experts. The passenger door on my cougar will now not open. The lock switch goes up and down as per normal using either a key from the outside or by operating it manually with your hand. However, neither the outside door button or the inside door latch when operated will open the door. Where do I start to try and fix the problem?
Thanks for any input.
