Hi,
previous owner misplaced the door lock on the passenger side. Since I drove it home in really bad weather, I scotch taped over the hole to prevent ice, snow sleet and slush to get in the door.
I purchased a new set of locks and had a door lock re-keyed to the old key. I also got the rod to connect to the assembly. Also got some panel clips, since I already suspect some are missing (loose at the bottom)
I now have 2 questions:
1- how big a job (timewise) is it to remove the panel to get to the inner workings? (I plan to adjust the window, and lubricate the workings while i'm there)
2- I got the shop manual for the '68 cougar, and I also got the PDF Ford shop manual. In The cougar manual, I can see the connbecting rod, but it just looks straight with the opposite 90 degree bend at both ends. My rod has a 22 degree bends near one end, and a 45 degree bend near the other end. ==> which end is up?
ok... maybe 3 questions... the eylet, on the keylock, where the rod is attached, points to the rear, or front. Just noticed now the door locks might not be interchangeable. since the lock pins/springs should be at the top to prevent rust and water getting to them.
thanks,
Jean
thanks,
Jean
