I need to replace the pins and bushings in the driver's side door hinges on my 69. That in itself is relatively easy. The question is how do I get the wiring harness for the power windows disconnected from the door or the body of the car ?
Last time I worked on the wiring harness I found that I couldn't get it out from the inside of the door and through the hole it goes through and even with the dash board out I couldn't get get all plugs disconnected on that end either. What am I missing ?
If there is no solution beyond total disassembly of the under-dash section, to get the wiring harness free on one end, I will find a way to suspend the door in the air while I do the hinges.
