My oil idiot light wasn't working when I turned on the ignition. Grounded out the oil sensor and sure enough it worked. Ordered a new one from WCCC http://www.cougarpartscatalog.com/b6az-9278-b-repro.html and was wondering if I needed to apply teflon tape to the threads? As you can see from the picture, it has some sort of, what appears to be sealant, already on the threads. Is that good enough? Also, does the wire attached to the unit just pull off? It's in a tight area so I just don't want to pull it and end up with problems. Is there a clip or something. THANKS
