1 - 8 of 8 Posts
can anybody help me on what newer cars, I can get the spindels off of to convert my 69 cougar to disk breaks
thanks for the help
spindles
I have heard from several different people that Granada front spindles bolt rite on. I have not done it my self, it's just what I've heard. ( thumper ):)
Breaks?
What are disk breaks?
Any relation to disc brakes?
Justin you can use 75-80? Granada spindles on your 69. But you will need to change the outer tie rod ends also. Remember that your Cougar is a Mustang under its skin so of course you can use the apporiate year Mustang spindles also. mm
ahem.... that 70 has discs. ( if i remember right ) i know there are suspension differences but hey, its all there...
The 68-70 disc brake spindle and calipers should all be the same.
It has the thicker (stronger) spindle and single piston floating caliper.
Super Moderator
Reply to crazy cat...
Actually the 68 and 69 disc setup is all parts common, changes occurred in the 69 Eliminator and were carried over into the 1970 - 73 production for all Cougars. These changes included different spindles, wheel bearings, rotors, and tie rod ends. The 70 - on up Comet, Maverick, Mustwang all share these parts too as well as the previously mentioned Granada, Mercury Monarch and Lincoln Versailles from 1975 - 1980.
Royce Peterson
1 - 8 of 8 Posts
