Hi, my 67 has manual drums on the front and want to changr them to disc. What is the simplest and most cost effective way to do this ? Thanks.
Simplest way: Call one of the many vendors offering conversion kits, give them a credit card number, and after the big brown truck drops off all the shiny new parts at your door, bolt them on your car.
Most cost effective way: Find a Cougar, Mustang, Torino, Maverick, etc. with a compatible disc system that's being parted out. Unbolt everything brake related and swap it to your car, replacing worn out components with parts store replacements as needed.
My friend used a kit with Ford Granada rotors and an aftermarket proportioning valve. You will need to re-balance the brake bias for the disc brakes.
I purchased a adjustable valve for the hotrod for $55 and is adjustable for disc and drum or 4 wheel disc .
