Used a tool from kooade to tap my W studs, and after screwing in the studs all the way, noticed some were slightly off perpendicular. Must have had some where the tapper wasn't properly aligned with the stud hole and raised up the tool slightly from where it should have been.
After I have the machinist take off some from the stud mounts, and install the guides and studs, can I "whack" lightly those studs so they're correctly aligned? Even after having a blast grinding the exhaust ports, I think a pair of aluminum heads are looking more and more essential. Eric
