When I crank over my 73 Cougar whether its cold or its just been running there is a dead spot and then it cranks over. Sometimes it is slow to crank over and sounds like it wont. The battery is fully charges, the alternator, voltage regulator are all good.
The mechanic I bring the car too said to replace the battery cables with OEM cables and if that doesnt work then maybe I will need a high torque Starter.
Do you think this is correct? Where would I purchase OEM Battery cables for a 73 Cougar?
Thank you in advance
