Signal Lights
Cougar kitty, I am interested in learning more about your signal light episode (or from anyone else that has had to venture down this path). My 67XR7 sat in my folks barn for the last 18 years. This past fall I finally got around to restoring the old cat. The undercarriage area is now completely re-done (brakes, shocks, springs, fuel system, drive train, axle and front end steering). We did a carb job on her and it now runs and drives. However, signal lights don't work at all. When I press the signal lever I get no indicator lights working anywhere. I checked the main fuse box above the accelerator pedal and the white fuse holder that comes out of the steering column. All fuses are OK. I sent away to the guy in Albequerque for the trouble shooting manual and purchased his electronic sequencer and signal replacement system (I have not yet recieved them). Do you think the old sequencer I have is the problem? I am interested in learning from those that know. Thanks.
