1 - 13 of 13 Posts
I'm still young and rarin to play with my cat. But, I do have a few questions for all those who know things:
What was the base transmission for a 73 xr7?
Is it true that a 351C has 8 bolts on the valve covers and a 351W has 6?
Does anyone know what safety features were in place on the 73 xr7 (the owner's manual's a little vague)?
Has anyone entered their beloved cat into any national shows?
Thanx all.
Your right about the bolts, sorry, can't help you with the other questions
I'm not sure, but I think the 73 came with a either a FMX or C6 depending on engine/options. Most common would be the FMX. If your car has the original drivetrain you can decode the data plate from the door here: http://members.aol.com/cougdb/decoder/decode.htm
Thanks for the site, but it lacks my car's ext color code. Code is 5M, and it's kind of a copper color. If I knew the name, i could get an exact repaint.
Is it 5M or SM, Ford had a SM colour in 1973 called Medium Copper Metallic
Thanx all.
Is it an H or a Q code? There were 7,945 (U) C6s behind the 351 H code 2V, and 24,680 (X) FMxs.
Q code 351CJs had 260 4 speeds (5) and 2,225 C6s (U)
The most obvious safety feature was the new 5 mph front bumper.
The AZ club just had a local show. There was a big Cougar Nationals in July in Cypress CA. See some of them here:
http://clubs.hemmings.com/cougarsd/
Our San Diego club had a local show in Sept.
Tim
thanks for the color info.
Cleo's a H code w/ X trans code. 351C w/ FMX auto
What's that DSO code all about anyway? Mine's coded for Denver....
:argue: <- ricer vs. hot rodder:p:
Discussion Starter #11
ok, new q:
what would I need to transform my H code to a Q code? and how hard is it to find?
Not sure you'd want to transform it into a Q code. The big port heads are a dog to drive and don't make enough bottom end.
You would probably be better off with a Edelbrock performer set-up (carb, cam and manifold), some head work to improve flow wothout the big ports, a set of headers and a good ignition set-up
You can probably go wilder but the drivability will go out the window and you'll have o run a lower ratio diff and hi stall converter to get it off the line (there's a lot of weight to get mobile)
HAve fun
Discussion Starter #13
Thanx
Thank you. Sounds like the basic mods my mom made to a 67 stang... her boyfriend at the time thrashed it racing (he was winning against an *******). SHe also told me my cat reminds her of her 73 pony car. hers was a smaller BOSS 302. y'all know what I got. I'll think about engine last, but am willing to take suggestions as to what I should do with what I got. Check out the pics in my gallery.
1 - 13 of 13 Posts
