1 - 2 of 2 Posts
I have a continuous creaky column, anyone know of a cure, I wouldn't mind if it just did it when you went over a bump, but it does it continuously. when the car is on the move and gets worse, longer one drives the car. I can stop it by putting pressure on the underside on one side and pressure on top side of steering wheel, so it is diffinitely coming from the column. I've tried CRC all the bolts (6) under the dash, which seems to stop it for half a mile or so, but it starts up with a quiet creak and slowly gets louder with each passing mile. Anyone else had a similar problem, if so, how did you cure it? TIA:uhoh:
Discussion Starter #2
Got rid of the incessant squeak, replaced seat cushions and vinyl covers, sprayed the springs with silicon and hey presto, no more squeaks!
1 - 2 of 2 Posts
