Hi all. Just joined the forum.
My 69 Coug wont crank with the key. When I try to start it, the voltage regulator clicks once. It also wont crank by jumping the s terminal on the starter relay, but cranks if I jump across both large terminals. My red/blue wire is hooked up, but I don`t know if it`s getting power because my test light is AWOL. I did find a black/red wire in the bundle under the regulator that was shoddily repaired, and is no longer hooked up. Where does this wire go? Thanks for any help.
