I have looked very hard at this. If you use a mustang h.o. computer, keep in mind that it uses the 351w firing order, not the 289/302. So if you just bolt the efi to your current engine it will idle like garbage and not run right. You can swap the wires on the injector harness around to obtain the 289/302 order or swap the cam to a 351w cam. I looked very hard at this and there are a lot of companies out there that sell the wiring harness, etc, but they are not cheap. windsor-fox and ron morris performance sell custom harness for like 600 bucks. Also bear in mind your fuel lines will have to be replaced and your electrical system will need to be tip top. Also the 86-93 intake manifold flows better than the 94-95. Don't forget that h.o.'s use a roller cam. It is very cool once you get it all hooked up though...lots of torque and great driveability.
