Hello my brotherhood! I need ya! I’ve finished working on my car, went to use it and: no flashers in dash, no tail lights. But if i pull night lights, then the rear lights are working.
I’ve checked the fuses: nothing wrong with them. But, i see this (see picture: circuit breaker seems burned)…i guess its a part that failed (circuit breaker). Is it logical? In Canada: where can i get parts fast?!??
Eric,
Did you ever resolve the wiring problem? It's a little spooky the way that the wire insulation is melting. If the breaker failed open, it would not allow current (no melting), and if it stayed stuck closed for some reason, it would not cause a problem unless something shorted out. So the problem would not be the breaker in either case, unless it is damaged from the short that occurred. So was there a short somewhere?
I like the color of your car btw.
