On my 68 XR7 the temp gauge doesn't work and i noticed that the sender units (screwed in to the intake manifold) in some of your guy's engine bays have a one prong/connector (I don't know the proper word for it) but mine has two?? but my wire from the firewall has one connector also!! Could someone clarify this for me?? Also if mine is wrong... what is the correct part number for this temp sender??
Many Thanks
Stu - :D
Discussion Starter #2
Oooops You may need this info!!
It is a 351 Windsor by the way!! A little detail i sometimes forget!! :p: Could someone check underneath there hood and have a look??
Once again, many thanks
Stu - :D
Stu, mine only has one post. I have a 351W as well. I would just go to the parts store and tell them you need a sending unit for a 68 Xr-7 with a gauge and not an idiot light. They should give you the right one. They are not expensive at all. I'm pretty sure I paid under $20.
Mark
Banned
The twp post is from a Fairlane or Galaxie. The singles are available for $6 at local parts store. Send me the old one will ya?
