I am needing/as well as wanting to replace my stock radiator and water pump. The radiator looks pretty nasty inside, and it leaks in 4 places when it gets hot enough. I'm pretty sure it is a 2-row. I am wanting to replace it with at least a 3-row aluminum, or should I go with a 4-row? I also thought about the trans cooler, can I get a radiator that I can hook up to the trans cooler lines? Or should I get a separate radiator for it? As far as the water pump, it is running fine, but I have read that a hi flow pump (such as from Stewarts) would be better for cooling.
I don't have a fan shroud right now, and it has a flex fan on it as well. Came that way when I bought last spring. I know a clutch fan and a shroud would help, but I need the radiator at least before spring as I will driving it everyday.
I am also wanting to get an Edelbrock Performer/RPM intake this summer. Should this be a consideration for the water pump? I wouldn't think so, but thought I'd ask.
Just filed my taxes last night electronically, so it is already burning a hole in my pocket.
Thanks guys!
