Ive been thinking about converting my front drum brakes to disc. I found a local source that has a pretty much complete set up which would includes the following;
SPINDLES
CALIPERS
ROTORS
RUBBER BRAKE LINES
master cyl
pro valve
Wants $250 for everything....
My question is that it came off a 72 Mustang Mach 1, will it fit? Here is a cpit of my car with newly acuired styled steel wheels.
Thanks,
John
You will certainly need the larger outer tie rod ends. 68/69 would be the same, 70 unique, 71-73 is the same. Not sure if 71-73 will fit but thinking they will as the repro control arms are the same 67-73.
Yes they fit you have get the larger tie rod ends but they screw right on the stock tie rods, but you have to redo the brake lines and use the later year rubber lines and drill a new mounting hole.
