I'm in the process of trying to track down a leak on my '72. When I first got the car, I filled the reservoir and cycled the top a few times with good results. I don't recall how many times in the last several months the top has been cycled but the top started having problems again.
I removed the seat and refilled the reservoir and again all is working however, this time after cycling several times, I placed a foil tray underneath with a paper towel (it should noted here that I did not replace the plug during this exercise). I left the top DOWN so I could see better. When I checked later, the paper towel was soaked. After refilling, I cycled through a couple of times and left the top UP. This time the paper towel only had what appeared to be some residual drops on it. I then put the top DOWN and noticed the reservoir wanted to over flow.
I'm confused.....I've read through several postings on this site that say to fill the reservoir with the top UP (as in closed) and failure to do so would potentially result in the plug being blown out when cycling the top up or down. Well, from what I see, when the top is in the down position, the reservoir is FULL to the point of wanting to overflow
Also, I've checked the cylinders. They have the appearance of OLD "dampness" rather than fresh "wetness" so not sure if it's leaking from the cylinders or not.
Is it possible for there to be a leak within the pump housing? I ask because I see wetness on the wires that protrude from the underside of the pump.
Thanks for any insights you can provide.
