I finally did a compression test on my '69 with the 390:
1: 140psi
2: 115-120psi
3: 110-115psi
4: 110-115psi
5: 130-135psi
6: 130psi
7: 120psi
8: 120psi
The plugs in cyls 3 & 4 were a nice bright white - all others were a bit of tan/brown/black (looked pretty normal to me).
I squirted a bit of oil in cyls 7 & 8 - the compression came up to 135psi. Since the engine wasn't really at operating temperature - I imagine most cylinders would do the same.
Finally - on cyl 3 - I did get some lower readings. Maybe 90-100. But after testing it again - it came up.
Any concerns here - or just drive it and hope for the best. The idle is set a little high - about 600. Otherwise it likes to miss sometimes when it is in gear.
1: 140psi
2: 115-120psi
3: 110-115psi
4: 110-115psi
5: 130-135psi
6: 130psi
7: 120psi
8: 120psi
