coil
Well, I run a blaster 2 coil and an MSD box, so the wire from the coil + to the firewall connector is not there anymore. Was that the resistance portion of the wire? or do I have to pull a certain amount of power through it to get the drop. I had used it as the "turn on" wire for the MSD box with no problems. I was going to also use it to turn on my GM alternator also and possibly run the electric choke on my edelbrock carb, though It may be easier to run it right off the alternator output, though I don't feel quite right about that for some reason.
