I have a number of accessories that all require a direct connection to constant 12v close to the battery - audio amp, 3g alternator charge wire, electric cooling fans, MSD 6AL. Right now they're all wired up to the constant 12v side of the starter solenoid.
It's a rats nest of fuses and wiring.
My question is how can I go about this in a clean and visually appealing way? I was planning on removing my external voltage regulator now that I have the internally regulated 3g alternator - which will clean up some of the problem.
Do people normally run a couple terminal blocks - one for constant and one for switched in the engine bay? I just want to eliminate the mess of wiring on my starter solenoid.
I need ideas / suggestions...
I have a 73 Cougar.
Thanks!
Jacob
I have a 73 Cougar.
Thanks!
Jacob
