Cougar parts here is a listing to go with the parts pictures...Make offer on single items in pictures or multiple items...Please refer to item # when emailing so I can see on list what I said about it...my email is((( tq28tz at aol.com ))))
1.2. Autolite alternator works this was on my 351C but switched to one wire alternator
3. Marker lights and bezels some pitting all studs intact
4. Gas cap cover parts stuff left from taking the best here’s what’s left pitting and missing
5. Parts from driver’s side mirror base xr7 as well as the top no mirror or guts
6. Heater control no ac (this may not work have no idea where it came from)
7. Yellow top ignition coil works took off for pertronix
8.70 steering wheel pad in black great condition
9, Felts for a 70 these are the two door panel side also on for the qtr window side never used only needed door side
10. Upper and lower hinge may need rebuild
11 Aftermarket hood hinge, hood latch and grill parts (offer on some or all)
12 Cougar coupe water shield new unopened
13 two sun visors black ok condition, kick panel needs repaint, steering color needs repaint, steering column cover is great condition it does have a crack at the bottom where goes under steering column but still looks good…offer on all or parts
14. Wiring for convertible top
15 radio bracket
16 69 assembly
17.18. 69 remote mirror all works great chrome has some pitting
19 Another yellow top coil took off for pertronix
20 xr7 switch wiring
21. 22. Washer tank this looks great with cap attached unfortunately won’t hold fluid was a crack at the seam in the front...but looks great
23. License plate bracket
24 -25 Windage tray for a 390-428-427…was to be installed on Jessica in fact almost was, I ground down all the rough edges, but we got it on gaskets and all and the bolts I bought were too short so having to drive her home from the shop had no way to get bolts just put on the new pan and never got back to getting it on plus having to buy new gaskets again and I really don’t need an addition horsepower gain
26.27. Aftermarket hood scoop for 69 or 70 needs bolts or to be fiber glassed into hood top in great shape
28. AC ducting pulled from a 69 mustang with AC in case I wanted AC (that’s not going to ever happen)
29. Standard clock with wiring was in a std gauge cluster I bought rare 69 and 70 option I don’t think the clock still works will have to be rebuilt WCC sells lens for these also I have one in my 70 Vert (I have about 6 gauge clusters I tore apart to get what I needed should put them all together)
30. A second Standard clock that I collected
31. 70 hood trim and an extra piece need to be polished some small dents in some pieces I bought some loose pieces and pick out the best ones for my car a spare set and this is what is left
32. Radio bezel aftermarket just an extra screws on back are still good
33, Standard over the glove box panel both in very good condition looks like dent in them must be glare very flat
34. red seat backs for 69 or 70 need to be reglued they came with the new seat covers for a 69 but I reused the original which are plastic but still look very good I have not seen these sold separately
35. Black seat backs for a 69 70 these are original black plastic (I recovered the seats and used the vinyl covered ones on that can’t remember why look good
36… 351 c 2bbl kick down rod with FMX
37… 351W 2 bbl kick down rod with FMX
38-39….70 steering wheel blue rim blow...This wheel is for a core only needs lots of work chips and missing rimblow switch
40…69-70door arm rest in white passenger needs repaint but still pliable original
41...1970 blue steering wheel pad in excellent condition still soft
42-43…69 XR7 steering wheel center the badge is in very good condition the burl wood is a 6 out of 10 better than some...right and left 80%good bottom 50% good..Back side screw holes are broken
44. 1969 black steering wheel pad in very good condition black
45. Another 70 steering wheel pad in black (I have no idea how I have so many) also in good shape
46 Carb spacer for 4 bbl ford part bought for my 428 but raised the carb too high to close the hood with the Ram air
47…70 center for steering wheel is in good shape no delaminating but the very center was very rusty
48…69 70 headlight switch I have 3 of these (I guess I needed a back up to my back up) so selling one off
49... Pulley have no idea which project it is left from about 6” hopefully someone knows that needs it
50…. Valve cover oil cap… In excellent condition…
51…2” drop blocks installed and realized 2” is too much from MU and would not take back after I installed it
52-56...69-70 Cougar (mustang) convertible top cover in? light aqua? this is an original cover in very good shape no stains and the plastic trim piece that goes in to the back of the seat is perfect..The original foam is there in great shape…There is a 1” tear in the corner that is not noticeable once top is on see picture
57-58 Valve covers for 351W I have 3 sets of these all ford original
