1 - 18 of 18 Posts
Harry, your website is very well done, with wonderful documentation. It's awesome you got your original Eliminator back. Thanks for sharing.
Discussion Starter · #7 ·
Thanks for the complements, guys. And check back often; I'll be making changes and updates almost daily as things are starting to happen a bit faster now ... finally!! I'll identify changes in an Updates section of the Home page (yet to be built).
My only critique is the diamond plate and black text pages (seemed like only some of the first pages) are hard to read. Otherwise, great job!
Agree w/Bob - those are hard to read but I know why you like them...I was trying to decide if your rocker moldings were in better shape than mine! LOL probably about the same (DANG IT!) Nice site though! And NICE CAT! I may have to bite the bullit and get the "repops" that have finally come to market. (Good thread on those BTW - Bob had a hand in many test-fits!!)
All I can say Harry is that you have more determination than anyone I have met. To keep going and not let any of the curves stop you, that this one has thrown your way, is impressive to say the very least. Great job on the website and recording of the build. One question about the engine on that valve and valve retainer, did you find the reason for all that wear? Did you check out the oil flow to and through that lifter, pushrod, etc? There must be a reason it failed like that and before you run it is the time to find it. You could run the oil pump with a drill and see if you get any oil up to that rocker. If you don't check it before you run the engine, then for sure lift that rocker cover and have a look to see that its getting oil when you do your first start up. Better safe than sorry.
Discussion Starter · #18 ·
No, I saw no reason for the wear. And I found no iron grit/filings in the pan either, so I'm assuming it happened a while ago and the grit was washed out with previous oil changes.
When I opened the valve cover, that spring and valve stem were just as oily as the others, so am assuming it got oil. I did replace the oil pump in case it had a problem. But I will do as you suggest, open that cover after runninng it to make sure it is getting oil. Thanks for the tip.
Hope you had a good meeting tonight; sorry I couldn't be there. We're on the road to Phoenix right now .. hoping to get some warm sun!!
1 - 18 of 18 Posts
