Been having some problems with the chargind system for a while, I think my battery may be over-charging. I took out the stock mechanical voltage regulator a month ago and put in a solid-state one I picked up from autozone because the mechanical one seemed to be faulty. With the new regulator, my voltage stays at a constant 14.50-14.59 volts when the engine is on. However, I seem to still get battery acid spilling out of my battery. What is a normal voltage for the regulator? If the current voltage is too high, is there any way to adjust my new voltage regulator? Could the battery be at fault? I don't have too much experience with electric matters, so any input would be great. Thanks.
