How much trouble am I going to run into to change my straight steering column in my 68 XR7 to a tilt 69 column?
ok good thanks. Now I have to paint the 69 column before I get started. The 69 column is a tilt/tilt away. I am planning on just using it as a tilt only.How much trouble am I going to run into to change my straight steering column in my 68 XR7 to a tilt 69 column?
The tilt-away interlock wiring harness is very different. You will need to obtain a 1968 tilt harness if you want the tilt-away function to work correctly.How much trouble am I going to run into to change my straight steering column in my 68 XR7 to a tilt 69 column?
